[mapguide-trac] #1500: Replace TreeViewAdv with vanilla TreeView for Resource Picker (was: Replace TreeViewAdv with vanilla TreeView for editor controls)
MapGuide Open Source trac_mapguide at osgeo.org
Tue Oct 26 05:17:53 EDT 2010
   Reporter:  jng      |       Owner:  jng
       Type:  task     |      Status:  new
   Priority:  low      |   Milestone:  Maestro-3.0
  Component:  Maestro  |     Version:
   Severity:  trivial  |    Keywords:
External_id:           |
Description changed by jng:
Old description:
> The TreeViewAdv control offers multi-selection of tree nodes. However
> this functionality is only used by the Site Explorer and is not required
> in any of the editor controls.
> For the sake of ensuring maximum compatibility with Mono (and removing
> the Aga.Controls.dll dependency when using the Maestro.Editors assembly),
> we should use the vanilla WinForms TreeView for editors which currently
> use the TreeViewAdv control.
New description:
 The TreeViewAdv control presents some problems with the Resource Picker in
 that it is not known (impossible?) to set an initial starting point, this
 makes some commands like "Save As" a bit cumbersome as you cannot specify
 a suggested save point thus requiring manual drilldowns to the specific
 folder (which is definitely cumbesome for deeply nested folder structures)
 By reverting to a vanilla TreeView, this can be done much easier
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1500#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
