[mapguide-trac] #1503: DWF Load Procedures not setting sheet extents
MapGuide Open Source trac_mapguide at osgeo.org
Tue Oct 26 05:34:43 EDT 2010
   Reporter:  jng      |       Owner:  jng
       Type:  defect   |      Status:  new
   Priority:  low      |   Milestone:  Maestro-3.0
  Component:  Maestro  |     Version:
   Severity:  trivial  |    Keywords:
External_id:           |
 The DWF Load Procedure should be initializing the created Drawing Source
 with all the relevant sheets and their matching extents. The extent
 information is found within an embedded xml file inside the DWF (DWF files
 are just zip files)
 Otherwise, attempting to preview a DWF-based layer will fail.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1503>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
