[mapguide-trac] #1507: SDK build profile
MapGuide Open Source trac_mapguide at osgeo.org
Tue Oct 26 23:09:37 EDT 2010
   Reporter:  jng      |       Owner:  jng
       Type:  task     |      Status:  new
   Priority:  low      |   Milestone:  Maestro-3.0
  Component:  Maestro  |     Version:
   Severity:  trivial  |    Keywords:
External_id:           |
 The Maestro "solution" should be split up into two sub-solutions
  * The Maestro application and supporting addins/applications
  * The Maestro API (and supporting libraries)
 This way the output of the API sub-solution can be packaged into a
 separate SDK distribution.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1507>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
