[mapguide-trac] #1428: GETMAPLEGENDIMAGE should omit empty layer groups from being rendered
MapGuide Open Source trac_mapguide at osgeo.org
Tue Sep 7 22:21:48 EDT 2010
   Reporter:  jng                |       Owner:
       Type:  enhancement        |      Status:  new
   Priority:  medium             |   Milestone:
  Component:  Rendering Service  |     Version:
   Severity:  trivial            |    Keywords:  legend, rendering
External_id:                     |
Comment(by jng):
 From a cursory glance of the legend rendering code, it appears that
 performance is not a function of the map size, rather it is a function of
 the height of the requested image.
 So whether a map has 8 layers or 800 layers, it will render at relatively
 the same speed given the same image height, since it will only render up
 to the specified height.
 This may become a factor if we're dealing with an large image height (in
 the 100k/millions of pixels high), but an image of such a height doesn't
 exactly fall into our standard user scenario (A4-sized printout from AJAX
 viewer, the only known consumer of GETMAPLEGENDIMAGE)
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1428#comment:3>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
