[mapguide-trac] #1433: Load procedures completion notification
MapGuide Open Source trac_mapguide at osgeo.org
Fri Sep 10 12:12:38 EDT 2010
   Reporter:  andrewd      |       Owner:  jng
       Type:  enhancement  |      Status:  new
   Priority:  low          |   Milestone:
  Component:  Maestro      |     Version:  2.1.0
   Severity:  trivial      |    Keywords:
External_id:               |
 When running a load procedure, there is no notification that the procedure
 has completed successfully. Adding a popup or something upon completion
 would be nice.
 Also, a slight bug - once it's done, you have to manually refresh to see
 your new data/layers. An automatic refresh should be done once the load
 procedure completes.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1433>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
