[mapguide-trac] #1434: Load procedures automatic type detection
MapGuide Open Source trac_mapguide at osgeo.org
Fri Sep 10 12:30:01 EDT 2010
   Reporter:  andrewd  |       Owner:
       Type:  defect   |      Status:  new
   Priority:  low      |   Milestone:
  Component:  General  |     Version:  2.1.0
   Severity:  trivial  |    Keywords:
External_id:           |
 It would be nice if the shp load procedure new enough to automatically
 determine which type (point, line, polygon) of shp file is being loaded,
 and then makes the resulting layer show only that type. Right now, you end
 up having to edit each layer manually to turn off any type that is not
 used - otherwise they show up in the legend.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1434>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
