[mapguide-trac] #1368: ACE:init missing in MapGuideCommon lib
MapGuide Open Source trac_mapguide at osgeo.org
Fri Sep 10 16:55:16 EDT 2010
   Reporter:  haris    |       Owner:  brucedechant
       Type:  defect   |      Status:  new
   Priority:  low      |   Milestone:
  Component:  General  |     Version:  2.2.0
   Severity:  trivial  |    Keywords:
External_id:           |
Description changed by brucedechant:
Old description:
> MapGuideCommon ( and others libraries) uses ACE without calling ACE:init.
> ACE:init() is called in MG server and web extension but as others
> libraries can be used independently it would be appropriate that
> ACE:init() is called in MapGuideCommon itself.
> Shouldn't be a problem to implement this as ACE:init can be called
> multiple times.
New description:
 !MapGuideCommon ( and others libraries) use ACE without calling ACE::init.
 ACE::init() is called in MG server and web extension but as other
 ACE::init() is called in !MapGuideCommon itself.
 Shouldn't be a problem to implement this as ACE::init can be called
 multiple times.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1368#comment:3>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
