[mapguide-trac] #1438: WMS or Raster - Request image with size > 2047 pixel results map with poor image quality
MapGuide Open Source trac_mapguide at osgeo.org
Wed Sep 15 21:59:51 EDT 2010
image quality
   Reporter:  liuar              |       Owner:  liuar
       Type:  defect             |      Status:  new
   Priority:  low                |   Milestone:
  Component:  Rendering Service  |     Version:  2.1.0
   Severity:  trivial            |    Keywords:
External_id:  1335217            |
 1. connect to a WMS server (http://osm.wheregroup.com/cgi-
 bin/osm_basic.xml?)
 2. create a map and add the WMS layer
 3. in !MapAgent web tier test, send a GetMapImage request in order to
 render the map, set map image size < 2047x2047
 4. in !MapAgent web tier test, send a GetMapImage request in order to
 render the map, set map image size where either height or width >
 2047pixel
 5. compare both maps
 Result: image quality drops significantly if map image size width or
 height is higher than 2047 pixel
 Expected: image quality should be same
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1438>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
