[mapguide-trac] #1443: MgProxyFeatureService::GetCapabilities is using a fixed api version 1.0.0
MapGuide Open Source trac_mapguide at osgeo.org
Sat Sep 18 23:01:48 EDT 2010
   Reporter:  wuma      |       Owner:  Mars Wu
       Type:  defect    |      Status:  new
   Priority:  high      |   Milestone:
  Component:  General   |     Version:  2.1.0
   Severity:  critical  |    Keywords:
External_id:  1342879   |
 Steps:
 - Run WebTier tests:Feature/GetCapabilities. It will get the capabilites
 for a certain FDO provider.
 - Keep the initial values for the test page except for changing the
 version to be 2.0.0
 - Submit the request
 You will find the response is always for 1.0.0 instead of 2.0.0.
 The reaons is like following:
 MgByteReader* MgProxyFeatureService::GetCapabilities(CREFSTRING
 providerName, CREFSTRING connectionString)
     MgCommand cmd;
     cmd.ExecuteCommand(m_connProp,                                  //
 Connection
                        MgCommand::knObject,                         //
 Return type expected
                        MgFeatureServiceOpId::GetCapabilities_Id,    //
 Command Code
                        2,                                           // No
 of arguments
                        Feature_Service,                             //
 Service Id
                        BUILD_VERSION(1,0,0),                        //
 Operation version
                        MgCommand::knString, &providerName,          //
 Argument#1
                        MgCommand::knString, &connectionString,      //
 Argument#2
                        MgCommand::knNone);                          // End
 of argument
     SetWarning(cmd.GetWarningObject());
     return (MgByteReader*)cmd.GetReturnValue().val.m_obj;
 The version is a fixed one: BUILD_VERSION(1,0,0) instead of the requested
 version
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1443>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
