[mapguide-trac] #1398: Upgrade to DbXml 2.5.16
MapGuide Open Source trac_mapguide at osgeo.org
Wed Sep 22 13:53:48 EDT 2010
   Reporter:  rohitr   |       Owner:  brucedechant
       Type:  task     |      Status:  new
   Priority:  low      |   Milestone:  2.3
  Component:  General  |     Version:  2.2.0
   Severity:  trivial  |    Keywords:  dbxml, upgrade, oem
External_id:           |
Changes (by brucedechant):
  * owner:  => brucedechant
Old description:
> 1.> Used DbEnv.get_DB_ENV and DbTxn.get_DB_TXN to get the underlying
> DB_ENV and DB_TXN structure and used that with the DbXml public
> interface.
> Changed
> {{{ environment->GetXmlManager().createTransaction(m_dbTxn))); }}} to
> {{{environment->GetXmlManager().createTransaction(m_dbTxn->get_DB_TXN())));
> }}} and {{{ m_xmlMan = XmlManager(&m_dbEnv, DBXML_ALLOW_EXTERNAL_ACCESS);
> to m_xmlMan = XmlManager(m_dbEnv.get_DB_ENV(),
> DBXML_ALLOW_EXTERNAL_ACCESS); }}} .
> 2.>Added a function DbXml::getContentAsDOM(const XmlValue &value). and
> used the constructor of the XmlValue to get an XmlValue handle on xmlDoc.
> The function is modified from an example in dbxml/example folder. Its a
> hack and I plan to make a proper class pretty soon.
> Created 2 files xercesDomTranslator.h and xercesDomTranslator.cpp. These
> are trivially modified forms of the file of the same name in dbxml
> example folder. However the function is trivial and I would make a class
> to encapsulate it, after I finish compilation.
> The function defined is
> {{{ XERCES_CPP_NAMESPACE_QUALIFIER DOMDocument *getContentAsDOM(const
> DbXml::XmlValue &value); }}}It requires an Xmlvalue and this is
> constructed by the constructor of the XmlValue class from the XmlDocument
> passed to it.
> 3.>Since XmlModify has been removed, we can use a simple Xquery Update to
> delete records. For example where our query was
> {{{ query = "/Role/Users/User[Name=<foobar>]"; }}} we change it to    {{{
> query = "delete nodes /Role/Users/User[Name=<foobar>]"; }}} and just
> execute the query with XmlManager::query().
> 4.>The function for assigning flags to DbEnv has been changed from
> set_flags to log_set_config. The define LOG_INMEMORY is no longer
> defined. It has been replaced with LOG_IN_MEMORY, which is functionally
> equivalent.
> 5.>Included db_cxx.h . Also removed the 'catch' for DbException. This
> isnt completely necessary but seeing that DbXml wants to encapsulate
> DbException inside XmlException and the functionality was similar, I
> removed it.
> catch (XmlException& e)
>         MgStringCollection arguments;
>         STRING message;
>         if (DB_LOCK_DEADLOCK == e.getDbErrno())
>             message = MgUtil::GetResourceMessage(
>                 MgResources::ResourceService, L"MgRepositoryBusy");
>         else
>             MgUtil::MultiByteToWideChar(string(e.what()), message);
>         arguments.Add(message);
>         mgException = new MgDbXmlException(methodName, __LINE__,
> __WFILE__, NULL, L"MgFormatInnerExceptionMessage", &arguments); \
> (static_cast<MgThirdPartyException*>(mgException.p))->SetErrorCode(e.getDbErrno());
> and
> catch (DbException& e)
>         STRING message;
>         if (DB_LOCK_DEADLOCK == e.get_errno())
>         else
>         mgException = new MgDbException(methodName, __LINE__, __WFILE__,
> (static_cast<MgThirdPartyException*>(mgException.p))->SetErrorCode(e.get_errno());
> Since XmlException would be triggered on a DbException and would give the
> same DbErrno and what() string, it seemed redundant to include this. Note
> the initial motivation was this to go with the philosophy of dbxml of
> hiding DB as much as possible. Unfortunately due to MapGuides use of DB
> objects in multiple places, that won't be possible.
> 6.>As there is no other option, but to go with LiveValues and afaik there
> appears to be no difference, I have just removed the lines.
New description:
 1.> Used !DbEnv.get_DB_ENV and !DbTxn.get_DB_TXN to get the underlying
 DB_ENV and DB_TXN structure and used that with the !DbXml public
 interface.
 Changed
 to
 and
 to
 m_xmlMan = XmlManager(m_dbEnv.get_DB_ENV(), DBXML_ALLOW_EXTERNAL_ACCESS);
 2.>Added a function DbXml::getContentAsDOM(const !XmlValue &value). and
 used the constructor of the !XmlValue to get an !XmlValue handle on
 xmlDoc. The function is modified from an example in dbxml/example folder.
 Its a hack and I plan to make a proper class pretty soon.
 are trivially modified forms of the file of the same name in dbxml example
 folder. However the function is trivial and I would make a class to
 It requires an !XmlValue and this is constructed by the constructor of the
 XmlValue class from the XmlDocument passed to it.
 set_flags to log_set_config. The define LOG_INMEMORY is no longer defined.
 It has been replaced with LOG_IN_MEMORY, which is functionally equivalent.
 5.>Included db_cxx.h . Also removed the 'catch' for DbException. This isnt
 removed it.
         STRING message;
         else
 and
         STRING message;
         else
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1398#comment:2>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
