[mapguide-trac] #1640: Error editing schema for both new and existing ODBC feature sources
MapGuide Open Source trac_mapguide at osgeo.org
Mon Apr 4 08:47:09 EDT 2011
   Reporter:  andrewd  |       Owner:  jng
       Type:  defect   |      Status:  new
   Priority:  high     |   Milestone:
  Component:  Maestro  |     Version:  2.1.0
   Severity:  blocker  |    Keywords:
External_id:           |
Comment(by jng):
 Select the text in that connection status field and drag all the way down.
 The error message is being cropped out.
 This is a small oversight. The textbox control doesn't have vertical
 scrollbars enabled when it should
 I've done some tweaking of the UI layout in this editor (r5671) to make
 the connection status field bigger.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1640#comment:3>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
