[mapguide-trac] #1651: Layer Definition editor defects and loose ends
MapGuide Open Source trac_mapguide at osgeo.org
Tue Apr 5 21:21:18 EDT 2011
   Reporter:  jng      |       Owner:  jng
       Type:  defect   |      Status:  new
   Priority:  medium   |   Milestone:  Maestro-3.0
  Component:  Maestro  |     Version:  2.1.0
   Severity:  major    |    Keywords:
External_id:           |
Description changed by jng:
Old description:
> The following defects were observed in the Layer Definition editor for
> Maestro 3.0 b3
>  * Deleting a vector scale range does not update the underlying XML
> content
>  * Adding a new vector scale range (control) does not create a default
> (line/point/area) rule controls
New description:
 Maestro 3.0 b3
 content
  * When generating a layer preview, the extents should be modified to fit
 into the visible scale ranges
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1651#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
