[mapguide-trac] #1661: Maestro 3 - Find/Replace
MapGuide Open Source trac_mapguide at osgeo.org
Tue Apr 12 04:16:22 EDT 2011
   Reporter:  crispinatime  |       Owner:
       Type:  enhancement   |      Status:  new
   Priority:  medium        |   Milestone:  Maestro-3.0
  Component:  General       |     Version:
   Severity:  major         |    Keywords:
External_id:                |
 In Maestro 2.1 there was a folder-level right-click option to invoke a
 find/replace menu on the XML for all items in that folder.
 This was designed to facilitate easier schema changes when migrating.
 For example, having an Oracle or ArcSDE schema on a development
 environment and packaging up for deployment, typically the schema name is
 different, though classes are the same.  Because the schema name is
 embedded in the .LayerDefinition (ArcSDE and KingOra both have the schema
 as part of the layers <FeatureName>) the find/replace provided a
 capability to update reliably and quickly.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1661>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
