[mapguide-trac] #1661: Maestro 3 - Find/Replace
MapGuide Open Source trac_mapguide at osgeo.org
Tue Apr 12 08:05:03 EDT 2011
 Reporter:  crispinatime  |         Owner:
     Type:  enhancement   |        Status:  closed
 Priority:  medium        |     Milestone:  Maestro-3.0
Component:  General       |       Version:
 Severity:  major         |    Resolution:  fixed
 Keywords:                |   External_id:
Comment(by jng):
 The r5695 submission does auto-save after find replace. Did the 2.x impl
 just opened the resource in the XML editor and *then* do the find/replace,
 allowing you to review the XML content before saving? If this is the case,
 I can modify this behaviour in 3.0 to match.
 Also nice find on the tab highlighting. When you've been working on the
 app for so long, some simple things just aren't readily apparent to you. A
 fix has been made with r5697
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1661#comment:3>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
