[mapguide-trac] #1664: Selection of rasterfiles via MG_DATA_PATH_ALIAS in composite type
MapGuide Open Source trac_mapguide at osgeo.org
Wed Apr 13 05:47:01 EDT 2011
   Reporter:  gBecker      |       Owner:  jng
       Type:  enhancement  |      Status:  new
   Priority:  low          |   Milestone:  Maestro-3.0
  Component:  Maestro      |     Version:
   Severity:  trivial      |    Keywords:
External_id:               |
Changes (by jng):
 * cc: zspitzer (added)
  * version:  2.2.0 =>
Comment:
 My one and only question to ask is: Did this feature actually work in
 Maestro 2.1.4?
 I say that because what we are doing is modifying an XML configuration
 document, and I don't think that MapGuide does tag substitution on XML
 configuration documents, meaning MG_DATA_PATH_ALIAS wouldn't be recognised
 if it comes from an XML config document, and that despite Maestro 2.1.4
 producing a syntatically correct XML document, it does nothing.
 If this worked in Maestro 2.1.4 and layers you make off of it produce the
 expected results, then I more than happy to put this feature back in. But
 I personally never worked much with the GDAL raster provider so I couldn't
 verify whether this feature works as originally intended.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1664#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
