[mapguide-trac] #1662: Maestro 3 - Cannot Save .LayerDefinition in XML Mode
MapGuide Open Source trac_mapguide at osgeo.org
Wed Apr 13 07:41:19 EDT 2011
 Reporter:  crispinatime  |         Owner:  jng
     Type:  defect        |        Status:  closed
 Priority:  high          |     Milestone:  Maestro-3.0
Component:  Maestro       |       Version:
 Severity:  major         |    Resolution:  fixed
 Keywords:                |   External_id:
Changes (by jng):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 Fixed in r5699. The problem was that the LayerDefinition xsd had its own
 dependency chain of xsds which weren't being loaded and fed to the XML
 validator causing the breakdown that you described. The fix was to load in
 the extra xsd dependencies if we have determined the resource type and
 version from the xml content.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1662#comment:2>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
