[mapguide-trac] #1666: Maestro 3 - XML Mode Toolbar Validation Fails
MapGuide Open Source trac_mapguide at osgeo.org
Wed Apr 13 11:35:40 EDT 2011
   Reporter:  crispinatime  |       Owner:  jng
       Type:  defect        |      Status:  new
   Priority:  low           |   Milestone:  Maestro-3.0
  Component:  Maestro       |     Version:
   Severity:  minor         |    Keywords:
External_id:                |
 The Maestro XML editor has it's own validation button (green tick) that is
 failing because it seems not to be adhering to the \Schemas path set-up in
 the options.
 The main toolbar validation check is OK in XML mode, it's just the XML
 editor toolbar that has the issue
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1666>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
