[mapguide-trac] #1667: MapGuide Maestro and Oracle Spatial
MapGuide Open Source trac_mapguide at osgeo.org
Fri Apr 15 10:03:24 EDT 2011
 Reporter:  kkorde   |         Owner:
     Type:  defect   |        Status:  closed
 Priority:  high     |     Milestone:  Maestro-3.0
Component:  General  |       Version:  2.0.2
 Severity:  major    |    Resolution:  wontfix
 Keywords:           |   External_id:
Changes (by jng):
  * status:  new => closed
  * resolution:  => wontfix
Comment:
 This error has nothing to do with Maestro and everything with how you've
 set up the FDO provider. Check the following:
  1. The King.Oracle provider you have downloaded is for FDO 3.3.x (this is
 the version of FDO your MapGuide 2.0.2 is using)
  2. You have installed the Oracle Instant Client and that the King.Oracle
 provider can correctly locate these libraries (OCI.dll). Loading
 KingOracleProvider.dll into depends.exe can help determine if it can
 locate these dlls.
 Please use the mailing list for problems like this in the future.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1667#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
