[mapguide-trac] #1664: Selection of rasterfiles via MG_DATA_PATH_ALIAS in composite type
MapGuide Open Source trac_mapguide at osgeo.org
Thu Apr 28 08:12:57 EDT 2011
   Reporter:  gBecker      |       Owner:  jng
       Type:  enhancement  |      Status:  new
   Priority:  low          |   Milestone:  Maestro-3.0
  Component:  Maestro      |     Version:
   Severity:  trivial      |    Keywords:
External_id:               |
Comment(by jng):
 Ok I've added support for this in r5724. If you can build from source, can
 you verify this worked as before?
 If you can't build from source, then I'll close this ticket anyway and
 just put out the final release of 3.0 and let the first trac ticket filed
 on this matter to tell me it doesn't work :)
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1664#comment:4>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
