[mapguide-trac] #1719: Maestro 3.1 - dragging new layer group to top of list makes it disappear
MapGuide Open Source trac_mapguide at osgeo.org
Wed Aug 3 10:42:04 EDT 2011
 Reporter:  jbirch   |         Owner:  jng
     Type:  defect   |        Status:  closed
 Priority:  low      |     Milestone:  Maestro-3.5
Component:  Maestro  |       Version:
 Severity:  minor    |    Resolution:  wontfix
 Keywords:           |   External_id:
Changes (by jng):
  * status:  new => closed
  * resolution:  => wontfix
Comment:
 Re-iterating comment in #1761
 Drag and drop re-ordering is not possible. This is due to dropping having
 two possible outcomes:
     Dropping onto an actual group folder. This signifies to add the
 dropped item inside the group folder being dropped on.
     Dropping between two top-level group folders. This signifies to insert
 the dropped group between the two folders in the logical order.
 Unfortunately, the tree control does not offer a usable way to detect drop
 type #2, despite showing the correct visuals. A suitable workaround is to
 use the new up/down buttons to re-arrange the logical group order.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1719#comment:8>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
