[mapguide-trac] #1770: Significant drop in Maestro RuntimeMap creation performance
MapGuide Open Source trac_mapguide at osgeo.org
Thu Aug 4 12:13:59 EDT 2011
   Reporter:  jng      |       Owner:  jng
       Type:  defect   |      Status:  new
   Priority:  low      |   Milestone:  Maestro-3.5
  Component:  Maestro  |     Version:
   Severity:  trivial  |    Keywords:
External_id:           |
Description changed by jng:
Old description:
> The RuntimeMap in trunk has significantly degraded creation performance.
> A unit test that creates a 200 layer, 50 group map takes 8.5s (!!!) to
> execute
> In Maestro 3.1 this exact same test case only took 600ms to execute
> One of the revisions to this class made since Maestro 3.1 must've been
> the cause. Investigate.
New description:
 execute
 Generally, the test suite also takes 3 times as long to execute as well.
 One of the revisions to this class made since Maestro 3.1 must've been the
 cause. Investigate.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1770#comment:2>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
