[mapguide-trac] #1779: Load MGP file failed with huge template maps
MapGuide Open Source trac_mapguide at osgeo.org
Mon Aug 15 01:36:00 EDT 2011
   Reporter:  christinebao      |       Owner:  ChristineBao
       Type:  defect            |      Status:  new
   Priority:  medium            |   Milestone:  2.3
  Component:  Resource Service  |     Version:  2.1.0
   Severity:  major             |    Keywords:
External_id:  1397129.01        |
 Report from Autodesk QA:[[BR]]
 In Site Admin load the attached MGP file and get error: An exception
 occurred in DB XML component. Error: DB_BUFFER_SMALL User memory too small
 for return value“ [[BR]]
 delete 3-4 10 Folders with MapGuide Administrator 2011 from the project
 the following message: „An exception occurred in DB XML component. Error:
 Not enough space“.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1779>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
