[mapguide-trac] #1781: GetPLOT command does not finish using raster data
MapGuide Open Source trac_mapguide at osgeo.org
Mon Aug 15 06:15:23 EDT 2011
   Reporter:  christinebao     |       Owner:  ChristineBao
       Type:  defect           |      Status:  new
   Priority:  low              |   Milestone:  2.3
  Component:  Mapping Service  |     Version:  2.1.0
   Severity:  major            |    Keywords:
External_id:  1406614          |
 Report from Autodesk QA:[[BR]]
 1. Use attached raster file to create a map.[[BR]]
 2. Open map agent, do Mapping-->GetPlot. Parameter as following:[[BR]]
         operation: GETPLOT
         Version: 1.0.0
         DWF Version: 6.01
         EPLOT version: 1.2
         Locale: en
         Client Agent: MapGuide Developer
         Map Devinition: Library://***/***.MapDefinition -- the map
 definition just created
         Width: 10
         Height: 10
         Margins: 0
         Units: in
      and following Commands:
         View center X: 758500
         View center Y: 190750
         view scale: 1000
         data extend: 758000,190250,759000,191250
         Display Dpi: 75
         show layers: ***  -- the layer of the raster
 [[BR]]
 Click submit, and it never ends.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1781>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
