[mapguide-trac] #1783: "Select radius" in AJAX viewer fails on FDO
source that doesn't support curve polygon
trac_mapguide at osgeo.org
Tue Aug 16 02:42:27 EDT 2011
#1783: "Select radius" in AJAX viewer fails on FDO source that doesn't support
curve polygon
Reporter: sparkliu | Owner:
Type: defect | Status: new
Priority: low | Milestone:
Component: AJAX Viewer | Version:
Severity: trivial | Keywords:
External_id: |
We should use a more common geometry type, such as "polygon", in case that
FDO doesn't support curve polygon.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1783>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
