[mapguide-trac] #1789: Refactor Maestro coordinate transform creation
MapGuide Open Source trac_mapguide at osgeo.org
Tue Aug 23 00:08:27 EDT 2011
   Reporter:  jng      |       Owner:  jng
       Type:  task     |      Status:  new
   Priority:  low      |   Milestone:  Maestro-4.0
  Component:  Maestro  |     Version:
   Severity:  trivial  |    Keywords:
External_id:           |
 Currently simple coordinate transformation is provided by creating a
 DefaultSimpleTransform class. This uses NTS/ProjNet behind the scenes to
 do the actual transformation.
 For LocalNative and Local connections, MgCoordinateSystem is available to
 us, so we should take advantage of that if possible.
 Each implementation of IServerConnection should provide the ability to
 create such transforms given the source and target CS wkts.
 The HTTP implementation would create a DefaultSimpleTransform
 The LocalNative and Local implementations would create one that wraps
 MgCoordinateSystem.
 For the consumer (Maestro), it would work with these transforms via the
 already existing ISimpleTransform interface
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1789>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
