[mapguide-trac] #1790: Features with similar join property values are not drawn in theme layer
MapGuide Open Source trac_mapguide at osgeo.org
Tue Aug 23 06:44:56 EDT 2011
   Reporter:  migueaguilera      |       Owner:
       Type:  defect             |      Status:  new
   Priority:  medium             |   Milestone:
  Component:  Rendering Service  |     Version:  2.2.0
   Severity:  major              |    Keywords:  join theme style
External_id:                     |
 I have experienced this problem with a SDF feature source with a Join to a
 SQL Server View. Theme layers based on that feature class fail to draw
 with the proper style the features with have similar values in the join
 property.
 For example, the feature with the join property value "CD000_HO027_" is
 drawn well, but the feature with the join property value "CD000_HO027A"
 always is drawn with the default style.
 If I replace the value "CD000_HO027_" with "CD000_HO027B" in the SDF
 feature property and also in the corresponding SQL Server row, then
 "CD000_HO027A" and "CD000_HO027B" features are both drawn with the correct
 style.
 Perhaps the reason is that both features have similar values and/or the
 underscore character?
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1790>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
