[mapguide-trac] #1791: RFC 116 Update -- Remove an unapproved interface which was erroneously added.
MapGuide Open Source trac_mapguide at osgeo.org
Wed Aug 24 14:27:04 EDT 2011
added.
 Reporter:  NormOlsen                        |         Owner:  NormOlsen
     Type:  defect                           |        Status:  closed
 Priority:  low                              |     Milestone:  2.3
Component:  General                          |       Version:  2.1.0
 Severity:  minor                            |    Resolution:  fixed
 Keywords:  CoordinateSystem Transformation  |   External_id:
Changes (by NormOlsen):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 The extraneous interface, MgCoordinateSystemTransform::!IsReentrant(), was
 removed from the interface file and the implementation files.  Also
 removed from the !GeometryConsoleTest module which was used to test the
 function of the interface and used it in performing other tests.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1791#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
