[mapguide-trac] #1792: Remove CS dictionary files from Maestro branch
MapGuide Open Source trac_mapguide at osgeo.org
Wed Aug 24 22:38:06 EDT 2011
   Reporter:  jng      |       Owner:  jng
       Type:  task     |      Status:  new
   Priority:  low      |   Milestone:  Maestro-4.0
  Component:  Maestro  |     Version:
   Severity:  trivial  |    Keywords:
External_id:           |
 Storing the CS-Map binary dictionaries for our Maestro Local Connection
 addin is actually not necessary.
 We can svn:external to the CS-Map repo, just like MapGuide does and just
 store the dictionary compiler binary, which is run as a post-build step
 for the addin project, to compile the source dictionaries and copy the
 processed result to the correct output directory.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1792>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
