[mapguide-trac] #1768: Implement RFC110 UI (was: Implement RFC110 UI - part 1)
MapGuide Open Source trac_mapguide at osgeo.org
Fri Aug 26 02:17:13 EDT 2011
   Reporter:  yangte  |       Owner:  Ted Yang
       Type:  task    |      Status:  new
   Priority:  high    |   Milestone:
  Component:  Server  |     Version:
   Severity:  major   |    Keywords:
External_id:          |
Comment(by yangte):
 The ProfilingAPI_GUI_part2.patch includes:
 [[BR]]
 1.  fixed layer info table head with vertical scroll
 [[BR]]
 2.  click layer info table row will display layer detail info
 [[BR]]
 3.  export works
 [[BR]]
 4.  fix some UI defects:
         * change "Select settings" to "Select setting..."
         * the ajax loading image can be clicked to submit the page (use
 <img> instead of <input type="img">)
         * add some icons
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1768#comment:3>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
