[mapguide-trac] #1585: Zoom Rectange doesn't work properly in Ajax viewer
MapGuide Open Source trac_mapguide at osgeo.org
Mon Jan 17 03:38:26 EST 2011
   Reporter:  wuma         |       Owner:  Mars Wu
       Type:  defect       |      Status:  new
   Priority:  low          |   Milestone:  2.2
  Component:  AJAX Viewer  |     Version:  2.2.0
   Severity:  trivial      |    Keywords:
External_id:               |
 With "Zoom Rectangle" command active, if I digitize a rectangle on screen
 which has a
 ratio of (width / height)  < ratio of (map width / map height)
 The map will zoom to a wrong scale. (see attached screen shot)
 The zoomed map should contain all features in the zoom rectangle.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1585>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
