[mapguide-trac] #1586: Incorrect LL84 wkt string existed in MapGuide code
MapGuide Open Source trac_mapguide at osgeo.org
Mon Jan 17 21:35:27 EST 2011
   Reporter:  liuar    |       Owner:  liuar
       Type:  defect   |      Status:  new
   Priority:  low      |   Milestone:
  Component:  Server   |     Version:  2.2.0
   Severity:  minor    |    Keywords:
External_id:  1377423  |
 !MapGuide defines LL84 using following wkt
 GEOGCS[\"LL84\",DATUM[\"WGS 84\",SPHEROID[\"WGS
 84\",6378137,298.25722293287],TOWGS84[0,0,0,0,0,0,0]],PRIMEM[\"Greenwich\",0],UNIT[\"Degrees\",0.01745329252]]";
 WGS 84 is an unrecognizable datum in CS component, which should be updated
 to WGS84
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1586>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
