[mapguide-trac] #1583: Tile service doesn't work with JPG
MapGuide Open Source trac_mapguide at osgeo.org
Fri Jan 28 00:57:12 EST 2011
   Reporter:  zspitzer      |       Owner:
       Type:  defect        |      Status:  new
   Priority:  high          |   Milestone:  2.2
  Component:  Tile Service  |     Version:  2.2.0
   Severity:  blocker       |    Keywords:
External_id:                |
Comment(by jng):
 Error.log is spammed with this entry for each failed GetTile request
 <2011-01-28T16:57:03>   2204    Ajax Viewer     ::1     Administrator
  Error: Problem:\nThe application encountered a problem and could not
 finish the operation you just requested properly.\n\nSolution:\nIf it\'s
 the first time you met this problem, try again or restart the application
 / session; otherwise, describe the steps to reproduce this problem to the
 server administrator for suggestions.
  StackTrace:
   - MgTileServiceHandler.ProcessOperation() line 83 file
 c:\builds\mg22win32\mgdev\server\src\services\tile\TileServiceHandler.cpp
   - MgOpGetTile.Execute() line 150 file
 c:\builds\mg22win32\mgdev\server\src\services\tile\OpGetTile.cpp
   - MgServerTileService.GetTile() line 260 file
 c:\builds\mg22win32\mgdev\server\src\services\tile\ServerTileService.cpp
   - MgServerRenderingService.RenderTile() line 265 file
 c:\builds\mg22win32\mgdev\server\src\services\rendering\ServerRenderingService.cpp
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1583#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
