[mapguide-trac] #1582: Sheybogan Parcels Layer doesn't render
MapGuide Open Source trac_mapguide at osgeo.org
Fri Jan 28 07:43:49 EST 2011
 Reporter:  zspitzer         |         Owner:
     Type:  defect           |        Status:  closed
 Priority:  high             |     Milestone:  2.2
Component:  Mapping Service  |       Version:  2.2.0
 Severity:  blocker          |    Resolution:  invalid
 Keywords:                   |   External_id:
Comment(by trevorwekel):
 Yes.  I noticed the same thing with the data set I was using.  The layer
 filter was originally authored as a string type but the FDO data type was
 coming back as an int.  I wonder if the FDO data type got flipped from a
 string to an int?
 In any case, the fix was simple.  Just change the filter text.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1582#comment:2>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
