[mapguide-trac] #1740: New Raster Layer Definitions should auto-select Feature Class
MapGuide Open Source trac_mapguide at osgeo.org
Tue Jul 5 14:19:29 EDT 2011
   Reporter:  andrewd      |       Owner:  jng
       Type:  enhancement  |      Status:  new
   Priority:  low          |   Milestone:
  Component:  Maestro      |     Version:  2.1.0
   Severity:  minor        |    Keywords:
External_id:               |
 When creating a new raster layer definition, once you select your Feature
 Source, Maestro should automatically select the Feature Class and Geometry
 Property for you - or at least try to. 9 times out of 10, the correct
 value here will just be "default:default" and "raster". Ideally, Maestro
 would check available Feature Classes and then automatically select the
 1st one, by default- which is how Maestro 1-2.x behaved.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1740>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
