[mapguide-trac] #1742: Deleting group causes error if no group selected (in Map Editor)
MapGuide Open Source trac_mapguide at osgeo.org
Wed Jul 6 10:31:02 EDT 2011
   Reporter:  andrewd  |       Owner:  jng
       Type:  defect   |      Status:  new
   Priority:  low      |   Milestone:
  Component:  Maestro  |     Version:  2.1.0
   Severity:  trivial  |    Keywords:
External_id:           |
 In v3.5.0.5977, edit a Map and then press the "remove selected group"
 button. An error window pops up, though can be dismissed without an issue.
 This happens both with nothing selected at all, and with a layer selected.
 The command does work as expected when you've got a group selected.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1742>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
