[mapguide-trac] #1744: Print Layout Omissions when selecting layout properties
MapGuide Open Source trac_mapguide at osgeo.org
Thu Jul 7 14:26:32 EDT 2011
   Reporter:  steveg   |       Owner:  jng
       Type:  defect   |      Status:  new
   Priority:  low      |   Milestone:
  Component:  Maestro  |     Version:
   Severity:  minor    |    Keywords:
External_id:           |
 When creating a new print layout and check/uncheck boxes for layout
 properties ("Title", "Legend", "URL", etc) it doesn't create a
 <LayoutProperties>
 callout or anything under it such as
 <ShowTitle>
 in the xml file.  However, if I have an existing Print Layout with layout
 properties and change the properties by checking/unchecking the properties
 it will change "true/false" under the corresponding property.  Seems to be
 the same issue on v3.1.0.5859 and 3.5b1 releases.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1744>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
