[mapguide-trac] #1746: Maestro .LayerDefinition - Display Composite Fail
MapGuide Open Source trac_mapguide at osgeo.org
Tue Jul 12 04:21:47 EDT 2011
 Reporter:  crispinatime  |         Owner:  jng
     Type:  defect        |        Status:  reopened
 Priority:  medium        |     Milestone:  Maestro-3.5
Component:  Maestro       |       Version:
 Severity:  minor         |    Resolution:
 Keywords:                |   External_id:
Changes (by crispinatime):
  * status:  closed => reopened
  * resolution:  fixed =>
Comment:
 Hi - not sure if this is another "oops" but it' still really the same bug
 description...
 1) Tick the "Display Composite"
 2) Select the Feature Style Editor to launch the "Symbol Instances" dialog
 3) Select Add -> Inline Simple Symbol (or Inline Compound Symbol) and
 bang!
 The method or operation is not implemented.
 System.NotImplementedException: The method or operation is not
 implemented.
    at
 Maestro.Editors.LayerDefinition.Vector.Scales.SymbolInstancesDialog.inlineSimpleSymbolToolStripMenuItem_Click(Object
 sender, EventArgs e) in
 e:\Projects\Maestro\Maestro.Editors\LayerDefinition\Vector\Scales\SymbolInstancesDialog.cs:line
 96
    at System.Windows.Forms.ToolStripItem.RaiseEvent(Object key, EventArgs
 e)
    at System.Windows.Forms.ToolStripMenuItem.OnClick(EventArgs e)
    at System.Windows.Forms.ToolStripItem.HandleClick(EventArgs e)
    at System.Windows.Forms.ToolStripItem.HandleMouseUp(MouseEventArgs e)
    at System.Windows.Forms.ToolStripItem.FireEventInteractive(EventArgs e,
 ToolStripItemEventType met)
    at System.Windows.Forms.ToolStripItem.FireEvent(EventArgs e,
    at System.Windows.Forms.ToolStrip.OnMouseUp(MouseEventArgs mea)
    at System.Windows.Forms.ToolStripDropDown.OnMouseUp(MouseEventArgs mea)
    at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons
 button, Int32 clicks)
    at System.Windows.Forms.Control.WndProc(Message& m)
    at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
    at System.Windows.Forms.ToolStrip.WndProc(Message& m)
    at System.Windows.Forms.ToolStripDropDown.WndProc(Message& m)
    at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message&
 m)
    at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
    at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg,
 IntPtr wparam, IntPtr lparam)
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1746#comment:5>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
