[mapguide-trac] #1745: Maestro Ergonomics
MapGuide Open Source trac_mapguide at osgeo.org
Thu Jul 21 08:45:21 EDT 2011
   Reporter:  crispinatime  |       Owner:  jng
       Type:  enhancement   |      Status:  new
   Priority:  low           |   Milestone:  Maestro-3.5
  Component:  Maestro       |     Version:
   Severity:  minor         |    Keywords:
External_id:                |
Comment(by jng):
 Ok my comments:
  1. The dialog should already be resizable. I'll increase the default size
  2. Reasonable request.
  3. Sorry, can't make assumptions about folder structure like this. What I
 can do however is have the dialog remember the last folder, and use this
 folder as the starting point the next time it is shown
  4. Inline renaming of Tree Nodes is the most unwieldy in the TreeView
 component, which is why I intentionally avoid renaming things this way.
 The suggested alternative improvements for the Rename dialog are good and
 I'll look to implement these changes instead.
  5. This was due to the outer parent control still apply old dimensions
 (when it was a series of stacked layer style controls). Will resize this
 to be more sane.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1745#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
