[mapguide-trac] #1754: Implement RFC 113
MapGuide Open Source trac_mapguide at osgeo.org
Thu Jul 21 17:43:07 EDT 2011
   Reporter:  Aleck        |       Owner:  Aleck
       Type:  enhancement  |      Status:  new
   Priority:  low          |   Milestone:  2.3
  Component:  General      |     Version:  2.2.0
   Severity:  trivial      |    Keywords:
External_id:               |
 This is to implement RFC 113
 (http://trac.osgeo.org/mapguide/wiki/MapGuideRfc113) .
 The new schema of SymbolDefinition, layer definition map definition and
 watermark
 definition is added. the new version numbers are all 2.4.0. Also, the
 Stylizer is
 modified to handle the additional scale properties. In evaluate method of
 SE_Polygon
 and SE_Polyline, the line buffer is scaled for each feature.
 The MdfParser and MdfModel is also update to version 2.4.0 for the above 4
 schemas
 The MdfModel server unit test was updated to test the new schema versions
 TESTING PERFORMED:
 Tested in MapGuide using mapagent to set a layer definition with scale
 factors
 being a constant & expression.  Both work. In the case of expression, I
 use
 featureid as the width, witch varies per-feature.
 The MdfModel unittest was run and passed.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1754>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
