[mapguide-trac] #1755: GETRESOURCECONTENT on a session-based resource crashes when FORMAT = application/json
MapGuide Open Source trac_mapguide at osgeo.org
Mon Jul 25 03:34:54 EDT 2011
application/json
   Reporter:  jng        |       Owner:
       Type:  defect     |      Status:  new
   Priority:  high       |   Milestone:
  Component:  Map Agent  |     Version:  2.2.0
   Severity:  critical   |    Keywords:
External_id:             |
Description changed by jng:
Old description:
> Invoke a GETRESOURCECONTENT mapagent operation on a session-based
> resource using the FORMAT of application/json.
> The mapagent handler will crash.
> This crash currently makes it impossible to dynamically load a Fusion
> ApplicationDefinition from the client side using an Anonymous session id.
New description:
 Invoke a GETRESOURCECONTENT mapagent operation on a session-based resource
 This doesn't happen if it is a library-based resource id, nor does it
 happen with the FORMAT of text/xml
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1755#comment:2>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
