[mapguide-trac] #1757: Quick Ploat cannot generate map picture in some non-English locale
MapGuide Open Source trac_mapguide at osgeo.org
Tue Jul 26 02:10:01 EDT 2011
   Reporter:  wuma     |       Owner:  Mars Wu
       Type:  defect   |      Status:  new
   Priority:  high     |   Milestone:
  Component:  General  |     Version:  2.2.0
   Severity:  major    |    Keywords:
External_id:  1406806  |
 In some non-English locale, for instance French or German where the
 decimal point and digit separator are not the same as English, if you run
 Quick Plot to generate a map picture, you will always get a message on the
 preview dialog saying: “The application resources required to generate the
 plot exceed the settings defined by the administrator”.
 The reason is that Quick Plot encodes (as string) the parameters like
 centerX, centerY, PaperSize etc. always in English format (. as decimal
 point and , as digit separator) but when parsing the values with aspx, php
 or jsp, current culture will be used then the value will be invalid.
 To fix it, the passed string values should be parsed always in English
 format.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1757>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
