[mapguide-trac] #1758: Selecting point features that have been styled using fonts a reprojected layer linked
MapGuide Open Source trac_mapguide at osgeo.org
Tue Jul 26 02:28:26 EDT 2011
layer linked
   Reporter:  hubu               |       Owner:  hubu
       Type:  defect             |      Status:  new
   Priority:  medium             |   Milestone:  2.3
  Component:  Rendering Service  |     Version:  2.2.0
   Severity:  trivial            |    Keywords:  Symbol
External_id:  1381956            |
 When styling point symbols using a font (or a simple symbol definition),
 and the layer is being reprojected, then clicking on the rendered symbol
 in the map does not select the feature unless the mouse is clicked exactly
 on the insertion point.
 Steps to reproduce:
 1.      Create a layer that uses a point feature class (eg: trees sdf from
 Sheboygan sample data).
 2.      Edit the layers point style to use Arial font symbol ‘a’
 character.  Choose something large like 1 centimetre in device space.
 3.      Add the new layer to a new map.
 4.      Change the co-ordinate system of the map to something different to
 that of the layer.
 5.      Preview the map and attempt to select a feature by clicking on it
 with the standard select tool
 6.      The feature is only selected if you click right in the centre.
 Click most places around the symbol does not select the feature.
 7.      Try the same thing with the point styled using a SymbolDefinition
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/1758>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
