[mapguide-trac] #1760: Replace TF.net with NTS (was: Remove dependency on TF.net)
MapGuide Open Source trac_mapguide at osgeo.org
Wed Jul 27 08:10:46 EDT 2011
   Reporter:  jng      |       Owner:  jng
       Type:  task     |      Status:  new
   Priority:  low      |   Milestone:
  Component:  Maestro  |     Version:
   Severity:  trivial  |    Keywords:
External_id:           |
Description changed by jng:
Old description:
> The tf.net library used by the Maestro API is rarely maintained and
> should be removed.
> When we look at what is actually being used from Topology.dll, which is
> the merged result of NTS, GeoAPI, ProjNet and other libraries
>  * Maestro exposes GeoAPI's geometry interfaces
>  * Maestro uses ProjNet's (weak, but sufficient) coordinate
> transformation capabilities
>  * The features unique to tf.net (MapGuide Geometry <-> GeoAPI geometry)
> can easily be replicated directly in the Maestro API itself.
> It will be simpler from a maintenance perspective to use NTS directly and
> provide our own MapGuide Geometry <-> custom geometry conversion. This
> opens up future lines of integration with NTS in the future, as we can
> keep NTS up to date as needed. Whereas tf.net is constrained by having
> seriously old version of NTS.
> To avoid leaking out the NTS dependency as Maestro currently does, it
> should define as much of the GeoAPI geometry interfaces directly in the
> Maestro API. The implementation specific Maestro API assemblies can then
> handle the required conversion logic as necessary. By not leaking out NTS
> dependencies, consuming applications will only need to reference the
> MaestroAPI assembly at compile time and not MaestroAPI + tf.net as it
> currently does.
New description:
 The tf.net library used by the Maestro API is rarely maintained and should
 be removed.
  * Maestro uses ProjNet's (weak, but sufficient) coordinate transformation
 capabilities
 ~~To avoid leaking out the NTS dependency as Maestro currently does, it
 currently does.~~
 This represents a breaking API change. Applications using the MaestroAPI
 will now have to reference the merged NTS assembly instead of Topology.dll
 and will need to update namespace references
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1760#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
