[mapguide-trac] #1762: Connect always shows "Cannot parse XML document whose stream is at end-of-file." when setting configuration
MapGuide Open Source trac_mapguide at osgeo.org
Wed Jul 27 21:57:43 EDT 2011
   Reporter:  sparkliu  |       Owner:
       Type:  defect    |      Status:  new
   Priority:  low       |   Milestone:
  Component:  General   |     Version:
   Severity:  trivial   |    Keywords:
External_id:            |
 This is because after setting configuration to a stream, the code forgets
 to reset the stream to put the position to the head of the stream so that
 a reader can read it.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1762>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
