[mapguide-trac] #1763: Mapguide Maestro: Ctrl-s shortcut does not work after returning from XML view
MapGuide Open Source trac_mapguide at osgeo.org
Thu Jul 28 09:21:37 EDT 2011
view
   Reporter:  gabrimonfa  |       Owner:  jng
       Type:  defect      |      Status:  new
   Priority:  low         |   Milestone:
  Component:  Maestro     |     Version:
   Severity:  trivial     |    Keywords:
External_id:              |
 Maestro 3.5b1 on Windows XP
 Step to reproduce:
 1 - Open a map or a weblayout in classic mode
 2 - Open XML view from the toolbar
 3 - Change something in the XML view
 4 - Press the button Save in the XML view
 5 - The layer correctly appears to be modified (the * before the name and
 the red highlighting in the tree panel) but Ctrl-s does not save the map
 (it is still possible to save the resource using the toolbar button)
 Note:
 1 - When I open layers the bug does not appear, I don't know if this is
 related to the fact that often the layers are marked as modified
 immediately after opening
 2 - I was not able to reproduce it in the Linux version
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1763>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
