[mapguide-trac] #1757: Quick Plot cannot generate map picture in some non-English locale
MapGuide Open Source trac_mapguide at osgeo.org
Thu Jul 28 11:03:24 EDT 2011
 Reporter:  wuma     |         Owner:  Mars Wu
     Type:  defect   |        Status:  reopened
 Priority:  high     |     Milestone:
Component:  General  |       Version:  2.2.0
 Severity:  major    |    Resolution:
 Keywords:           |   External_id:  1406806
Comment(by wuma):
 Replying to [comment:6 thomaslorenzon]:
 > I tried to implement on MGE2012 (italian version) your patch but it
 doesn't work (a black image is generated).
 > Then I had a look at GeneratePicture.php and found a possible solution.
 > Modify row 106 as follow:
 > $mapAgent
 .="/mapserver2012/mapagent/mapagent.fcgi?VERSION=1.0.0&OPERATION=GETMAPIMAGE"
 > Now for me it works but I known that it doesn't work with MGOS.
 > Someone can change it and do it better?
 > Thanks, Thomas
 Can you tell me your configuration? Windows or Linux, IIS or Apache? The
 $mapAgent cannot be changed as you mentioned, because it will not work if
 your Web Extension is behind a Http proxy server. And you cannot use
 http://locahost either, because it doesn't work with Apache + Php.
 http://127.0.0.1 should always work with IPv4. And with RFC 118, I plan to
 change the way of generating the print picture from calling Http API to
 calling Web Tier API. And a new MgMap::SetDisplayDpi will be exposed to
 support the change.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1757#comment:7>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
