[mapguide-trac] #1765: Add a new command "MapTip" to enable/disable map tootips
MapGuide Open Source trac_mapguide at osgeo.org
Fri Jul 29 05:26:32 EDT 2011
   Reporter:  hubu         |       Owner:  hubu
       Type:  enhancement  |      Status:  new
   Priority:  medium       |   Milestone:  2.3
  Component:  AJAX Viewer  |     Version:  2.2.0
   Severity:  trivial      |    Keywords:  tooltips enable/disable
External_id:               |
 Currently in MapGuide, the client sends "QueryMapFeatures?" request to get
 the tooltips every time we move the cursor. However, most of the requests
 are unnecessary and useless for the end-user. For example, when the user
 are doing measure/pan/zoom, the tooltips are redundant for the user. If we
 remove these unnecessary requests, we can reduce server's overload.
 With this widget,we can enable\disable the map tooltips. Then the user has
 an opportunity to disable the map tooltip to reduce server's overload, and
 the user still can enable the tooltips again.
 By default, the tooltip is enabled, so it won't affect the original users.
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/1765>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
