[mapguide-trac] #1705: MAPAGENT call crashes webservers (IIS & Apache)
MapGuide Open Source trac_mapguide at osgeo.org
Wed Jun 1 04:27:03 EDT 2011
   Reporter:  zspitzer   |       Owner:
       Type:  defect     |      Status:  new
   Priority:  high       |   Milestone:  2.2
  Component:  Map Agent  |     Version:  2.2.0
   Severity:  critical   |    Keywords:
External_id:             |
Comment(by jng):
 I did some digging on this matter with a 2.2 branch copy.
 The offending line is here:
 http://trac.osgeo.org/mapguide/browser/branches/2.2/MgDev/Web/src/ApacheAgent/ApacheAgent.cpp#L153
 This method is throwing a MgInvalidArgumentException with the error id
 MgInvalidStringConversion
 The root location where this exception is thrown is at
 MgUtil::MultiByteToWideChar
 http://trac.osgeo.org/mapguide/browser/branches/2.2/MgDev/Common/Foundation/System/Util.cpp#L287
 The mgmapagent_handler() function does not have an exception handler for
 any MgException (or derivatives) and because of this the
 MgInvalidArgumentException that is thrown is unhandled and derails the
 Apache Web Server process
 Perhaps we should have an exception handler for MgException here, and
 write out a bad request string response?
 Perhaps something similar is happening with the ISAPI and CGI handlers?
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1705#comment:5>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
