[mapguide-trac] #332: Fusion: Buffer tool in Aqua Template should open the task pane.
MapGuide Open Source trac_mapguide at osgeo.org
Tue Jun 14 11:03:05 EDT 2011
 Reporter:  jng                 |         Owner:  pagameba
     Type:  defect              |        Status:  closed
 Priority:  medium              |     Milestone:
Component:  Fusion Templates    |       Version:  2.0.0
 Severity:  minor               |    Resolution:  fixed
 Keywords:  fusion buffer aqua  |   External_id:  1054712
Changes (by jng):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 The problem is in the ApplicationDefinition.xml of the template dir. Ones
 generated by Maestro produce the correct behavior.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/332#comment:10>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
