[mapguide-trac] #333: Fusion: Select polygon tool/widget does not tell you how to abort/finish the process
MapGuide Open Source trac_mapguide at osgeo.org
Tue Jun 14 11:16:11 EDT 2011
the process
 Reporter:  jng     |         Owner:  pagameba
     Type:  defect  |        Status:  closed
 Priority:  medium  |     Milestone:
Component:  Fusion  |       Version:  2.0.0
 Severity:  minor   |    Resolution:  invalid
 Keywords:  fusion  |   External_id:
Changes (by jng):
  * status:  new => closed
  * resolution:  => invalid
Comment:
 This is an OpenLayers level usability issue. As the selection widgets does
 not use the Task Pane, there's no place to place the usage instructions.
 Whatever fix should be made at the OpenLayers level instead of here.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/333#comment:3>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
